TF-A-Tests boot
Overview of tf-a-tests boot
The Trusted Firmware-A Tests (TF-A-Tests) is a suite of baremetal tests to exercise the Trusted Firmware-A (TF-A) features from the Normal World. Neoverse Reference Design (RD) platform software stack supports booting TF-A-Tests. This enables strong TF-A functional testing without dependency on a Rich OS. Refer the Trusted Firmware-A Tests Documentation for more details.
This document describes how to build the Neoverse RD platform software stack and and use it to boot TF-A-Tests on the Neoverse RD FVP.
Download the platform software
Skip this section if the required sources have been downloaded.
To obtain the required sources for the platform, follow the steps listed on the Setup Workspace page. Ensure that the platform software is downloaded before proceeding with the steps listed below. Also, note the host machine requirements listed on that page which is essential to build and execute the platform software stack.
Build the platform software
This section describes the procedure to build the platform firmware required to boot TF-A-Tests on Neoverse RD platforms.
To build the software stack, the command to be used is
./build-scripts/build-test-tf-a-tests.sh -p <platform name> <command>
Supported command line options are listed below
<platform name>
Lookup for a platform name in Platform Names.
<command>
Supported commands are
cleanbuildpackageall(all of the three above)
Note
On networks where git port is blocked, the build procedure might not progress. Refer the troubleshooting guide for possible ways to resolve this issue.
Examples of the build command are
Command to clean, build and package the RD-N2 software stack required for TF-A-Tests boot on RD-N2 platform:
./build-scripts/build-test-tf-a-tests.sh -p rdn2 all
Command to perform an incremental build of the software components included in the software stack for the RD-N2 platform.
./build-scripts/build-test-tf-a-tests.sh -p rdn2 build
Note
This command should be followed by the package command to complete the
preparation of the FIP.
Command to package the previously built software stack and prepare the FIP.
./build-scripts/build-test-tf-a-tests.sh -p rdn2 package
Boot TF-A-Tests
After the build of the platform software stack for TF-A-Tests is complete, the following commands can be used to start the execution of the selected platform fastmodel and boot the TF-A-Tests. Examples on how to use the command are listed below.
To boot TF-A-Tests, the commands to be used are
Set
MODELpath before launching the model:export MODEL=<absolute path to the platform FVP binary>
If platform is SGI-575:
cd model-scripts/sgi
If platform is an RD:
cd model-scripts/rdinfra
Launch TF-A-Tests boot:
./tftf.sh -p <platform name> -a <additional_params> -n [true|false]
-p <platform name>
-n [true|false] (optional)
Controls the use of network ports by the model. If network ports have to be enabled, use ‘true’ as the option. Default value is set to ‘false’.
-a <additional_params> (optional)
Specify any additional model parameters to be passed. The model parameters and the data to be passed to those parameters can be found in the FVP documentation.
Example commands to boot TF-A-Tests are as listed below.
Command to start the execution of the RD-N2 model to boot TF-A-Tests:
./tftf.sh -p rdn2
Command to start the execution of the RD-N2 model to boot TF-A-Tests with network enabled. The model supports virtio.net allowing the software running within the model to access the network:
./tftf.sh -p rdn2 -n true
Command to start the execution of the RD-N2 model with networking enabled and to boot TF-A-Tests. Additional parameters to the model are supplied using the
-acommand line parameter:./tftf.sh -p rdn2 -n true -a "-C board.flash0.diagnostics=1"
Once the tests complete, a message similar to the following output will be displayed on the non-secure UART terminal. This demonstrates the usage of TF-A Tests on Arm infrastructure reference design platforms.
******************************* Summary ******************************* > Test suite 'Framework Validation' Passed > Test suite 'Timer framework Validation' Passed > Test suite 'Boot requirement tests' Passed > Test suite 'Query runtime services' Passed > Test suite 'PSCI Version' Passed > Test suite 'PSCI Affinity Info' Passed > Test suite 'CPU Hotplug' Passed > Test suite 'PSCI CPU Suspend' Passed > Test suite 'PSCI STAT' Passed > Test suite 'PSCI NODE_HW_STATE' Passed > Test suite 'PSCI Features' Passed > Test suite 'PSCI MIGRATE_INFO_TYPE' Passed > Test suite 'PSCI mem_protect_check' Passed > Test suite 'SDEI' Passed > Test suite 'Runtime Instrumentation Validation' Passed > Test suite 'TRNG' Passed > Test suite 'IRQ support in TSP' Passed > Test suite 'TSP handler standard functions result test' Passed > Test suite 'Stress test TSP functionality' Passed > Test suite 'TSP PSTATE test' Passed > Test suite 'EL3 power state parser validation' Passed > Test suite 'State switch' Passed > Test suite 'CPU extensions' Passed > Test suite 'ARM_ARCH_SVC' Passed > Test suite 'Performance tests' Passed > Test suite 'SMC calling convention' Passed > Test suite 'FF-A Setup and Discovery' Passed > Test suite 'SP exceptions' Passed > Test suite 'FF-A Direct messaging' Passed > Test suite 'FF-A Power management' Passed > Test suite 'FF-A Memory Sharing' Passed > Test suite 'SIMD,SVE Registers context' Passed > Test suite 'FF-A Interrupt' Passed > Test suite 'SMMUv3 tests' Passed > Test suite 'FF-A Notifications' Passed > Test suite 'PMU Leakage' Passed > Test suite 'DebugFS' Passed > Test suite 'Realm payload tests' Passed ================================= Tests Skipped : 122 Tests Passed : 60 Tests Failed : 0 Tests Crashed : 0 Total tests : 182 ================================= NOTICE: Exiting tests.
Copyright (c) 2022-2023, Arm Limited. All rights reserved.
