Buildroot boot
What is Buildroot?
Buildroot is a simple, efficient and easy-to-use tool to generate a complete Linux systems through cross-compilation. In order to achieve this, buildroot is able to generate a cross-compilation toolchain, a root filesystem, a Linux kernel image and a bootloader for a target and can be used for any combination, independently, one can for example use an existing cross- compilation toolchain, and build only the root filesystem with buildroot.
Buildroot supports numerous processors and their variants from various families such as, PowerPC, MIPS, and ARM processors, etc. It comes with default configurations for several boards available off-the-shelf.
Online documentation for buildroot can be found here.
Overview of Buildroot Boot
Buildroot boot on Neoverse Reference Design platforms allows the use of buildroot as the filesystem and boot the software stack on the fast model. This document describes the procedure to build and execute the software stack with buildroot as the root filesystem.
Sync the required platform software
Skip this section if the required sources have been downloaded.
To obtain the required sources for the platform, follow the steps listed on the Setup Workspace page. Ensure that the platform software is downloaded before proceeding with the steps listed below. Also, note the host machine requirements listed on that page which is essential to build and execute the platform software stack.
Build the platform software
This section describes the procedure to build the disk image for buildroot boot. The disk image consists of two partitions. The first partition is a EFI partition and contains grub. The second parition is a ext3 partition and contains the linux kernel image. Examples on how to use the build command for buildroot boot are listed below.
To build the software stack, the command to be used is
./build-scripts/rdinfra/build-test-buildroot.sh -p <platform name> <command>
Supported command line options are listed below
<platform name>
Lookup for a platform name in Platform Names.
<command>
Supported commands are
cleanbuildpackageall(all of the three above)
Examples of the build command are
Command to clean, build and package the software stack needed for the buildroot boot on RD-N2 platform:
./build-scripts/rdinfra/build-test-buildroot.sh -p rdn2 all
Command to perform an incremental build of the software components included in the software stack for the RD-N2 platform.
./build-scripts/rdinfra/build-test-buildroot.sh -p rdn2 build
Note
This command should be followed by the package command to complete the
preparation of the FIP and the disk image.
Command to package the previously built software stack and prepares the FIP and the disk image.
./build-scripts/rdinfra/build-test-buildroot.sh -p rdn2 package
Modifying buildroot target filesystem (optional)
Buildroot supports a number of pre-configured packages, customizations across various components, supports a number of pre-configured packages, and also allows adding or modifying files on the target filesystem. This provides the ability to create a richer filesystem compared to busybox.
Though not recommended, for temporary modifications, it is possible to modify the buildroot target filesystem directly and rebuild the image. The target file- system is available under out/arm64/target/ directory in buildroot source. After making required changes, build the software stack again to rebuild the target filesystem image.
Note
If the buildroot repo is cleaned, these changes will be lost.
After the changes are made, run the build command for buildroot and package it. Examples of the incremental build command are
Command to perform an incremental build of the buildroot component included in the software stack for the RD-N2 platform.
./build-scripts/build-buildroot.sh -p rdn2 build
Booting with Buildroot as the filesystem
After the build of the platform software stack for buildroot boot is complete, the following command starts the execution of the selected platform fastmodel and the software boots up to the buildroot prompt. Examples on how to use the command are listed below.
To boot up to the buildroot prompt, the command to be used is
Set
MODELpath before launching the model:export MODEL=<absolute path to the platform FVP binary>
If platform is SGI-575:
cd model-scripts/sgi
If platform is an RD:
cd model-scripts/rdinfra
Launch buildroot boot:
./boot-buildroot.sh -p <platform name> -a <additional_params> -n [true|false]
-p <platform name>
-n [true|false] (optional)
Controls the use of network ports by the model. If network ports have to be enabled, use ‘true’ as the option. Default value is set to ‘false’.
-a <additional_params> (optional)
Specify any additional model parameters to be passed. The model parameters and the data to be passed to those parameters can be found in the FVP documentation.
Example commands to boot with buildroot as the filesystem are as listed below.
Command to start the execution of the RD-N2 model to boot up to the buildroot prompt:
./boot-buildroot.sh -p rdn2
Command to start the execution of the RD-N2 model to boot up to the buildroot prompt with network enabled. The model supports virtio.net allowing the software running within the model to access the network:
./boot-buildroot.sh -p rdn2 -n true
Command to start the execution of the RD-N2 model with networking enabled and to boot up to the buildroot prompt. Additional parameters to the model are supplied using the
-acommand line parameter:./boot-buildroot.sh -p rdn2 -n true -a "-C board.flash0.diagnostics=1"
Copyright (c) 2021-2023, Arm Limited. All rights reserved.
