WinPE boot
WinPE boot
Neoverse Reference Design (RD) platform software stack supports the boot of Windows Preinstallation Environment (WinPE) on RD platforms. A pre-built WinPE disk image is connected as a SATA disk to the fixed virtual platform (FVP). During boot, the platform firmware detects the connected WinPE disk image and boots from it.
Download the platform software
Skip this section if the required sources have been downloaded.
To obtain the required sources for the platform, follow the steps listed on the Setup Workspace page. Ensure that the platform software is downloaded before proceeding with the steps listed below. Also, note the host machine requirements listed on that page which is essential to build and execute the platform software stack.
Build the platform software
This section describes the procedure to build the platform firmware required to boot WinPE on Neoverse RD platforms.
To build the RD software stack, the command to be used is
./build-scripts/build-test-uefi.sh -p <platform name> <command>
Supported command line options are listed below
<platform name>
Lookup for a platform name in Platform Names.
<command>
cleanbuildpackageall(all of the three above)
Examples of the build command are
Command to clean, build and package the RD-N2 software stack required for WinPE boot on the RD-N2 platform:
./build-scripts/build-test-uefi.sh -p rdn2 all
Command to remove the generated outputs (binaries) of the software stack for the RD-N2 platform:
./build-scripts/build-test-uefi.sh -p rdn2 clean
Command to perform an incremental build of the software components included in the software stack for the RD-N2 platform:
./build-scripts/build-test-uefi.sh -p rdn2 build
Note
This command should be followed by the package command to complete the
preparation of the fip image.
Command to package the previously built software stack and prepares the fip image:
./build-scripts/build-test-uefi.sh -p rdn2 package
Obtain the WinPE disk image
Obtain a pre-built WinPE disk image to use it as the disk image to boot from. Refer to this page for more information.
Note
WinPE version should be 20262 or higher.
Boot WinPE
To boot from the WinPE disk image, the commands to be used are:
Set
MODELpath before launching the model:export MODEL=<absolute path to the platform FVP binary>
If platform is SGI-575:
cd model-scripts/sgi
If platform is an RD:
cd model-scripts/rdinfra
Launch the FVP to boot WinPE:
./distro.sh -p <platform name> -d <satadisk_path> -a <additional_params> -n [true|false]
-p <platform name>
-d <satadisk_path>
Absolute path to the WinPE disk image created using the previous section.
-n [true|false] (optional)
Controls the use of network ports by the model. If network ports have to be enabled, use ‘true’ as the option. Default value is set to ‘false’.
-a <additional_params> (optional)
Specify any additional model parameters to be passed. The model parameters and the data to be passed to those parameters can be found in the FVP documentation.
Example commands to boot WinPE are as listed below.
Command to begin the WinPE boot on the RD-N2 platform using a
WinPE_arm64.isopre-built disk image. Follow the instructions on console to complete the WinPE boot../distro.sh -p rdn2 -d /absolute/path/to/WinPE_arm64.iso
Copyright (c) 2020-2023, Arm Limited. All rights reserved.
