Collaborative Processor Performance Control (CPPC)
Overview of CPPC test
Collaborative Processor Performance Control (CPPC) is a mechanism for the OS to manage the performance of the processor core on a contiguous and abstract performance scale. The CPPC support as implemented for Neoverse Reference Design platforms requires the CPUs to support the Arm v8.4 AMU functionaliry. So the support for CPPC is applicable for platforms that have Arm v8.4 or higher CPU.
The CPPC kernel framework has two parts, monitoring the CPU performance and scale the CPU performance. In the monitoring part, the OS uses the AMU extension which is introduced in ARMv8.4. Especially the ‘Processor frequency counter’ and the ‘Constant frequency counter’. For calculating the processor frequency, the values of the processor frequency counter and constant frequency counter are captured at two instances, say 2 microseconds between the instances and get the delta between these two counts. The constant frequency is known hence the processor frequency is calculated as:
(delta processor frequency count / delta constant frequency count)
* constant frequency
In the controlling part, the OS requests the desired performance to the platform firmware through a non-secure channel between the OS and platform firmware.
This document focus on the procedure to validate CPPC functionality, obtaining the CPU’s current operating frequency, procedure to scale CPU frequency and the scaling governor.
Download and build the required platform software
For downloading and building the platform firmware, refer Busybox Boot or Buildroot boot
documentation. To enable CPPC from ACPI, update the CPPC_EN=TRUE variable
from SgiPlatform.dsc.inc before build.
Note
For Busybox Boot or
Buildroot boot, in Linux kernel defconfig
ensure CONFIG_ACPI_CPPC_CPUFREQ=y.
Changing the scaling governor
For changing the frequency governor, the procedure is:
Boot the platform to command line prompt.
Read the scaling governor entry to get the current governor in action.
cat /sys/devices/system/cpu/cpufreq/policy<x>/scaling_governor For RD platforms, x = 0, 1, 2, ... (number of CPUs - 1)
Read the scaling available governors entry to get list of supported governors.
cat /sys/devices/system/cpu/cpufreq/policy_x/scaling_available_governors
To change governor, write the preferred governor to scaling governor entry.
echo governor_name > /sys/devices/system/cpu/cpufreq/policy<x>/scaling_governor Here the governor_name is obtained from step 3.
Repeat step 3 to confirm the governor change is taken into effect.
Validating CPPC functionality
For validating the CPPC functionality, it is recommended to use ‘userspace’ governor. The procedure for validation is:
Set ‘userspace’ governor as the scaling governor.
echo userspace > /sys/devices/system/cpu/cpufreq/policy<x>/scaling_governor
Write the desired frequency in KHz to the scaling setspeed entry.
echo freq_in_KHz > /sys/devices/system/cpu/cpufreq/policy<x>/scaling_set_speed For RD-V1 variants, the supported frequencies in GHz are 1.3, 1.5, 1.7, 2.1 and 2.6 For RD-N2 variants, the supported frequencies in GHz are 2.3, 2.6 and 3.2 For RD-Fremont variants, the supported frequencies in GHz are 1.7, 2.0, 2.3, 2.6, 2.9 and 3.2
Read the cpuinfo current frequency entry, to obtain the current operating frequency of the CPU, using the AMU extension.
Additional precautions for FVP based platforms
The CPPC frequency monitoring part should be executed with highest time precision. For FVP based platforms, to improve the time precision, follow the steps below.
Export these variables before launching the model
export FM_SCX_ENABLE_TIMER_LOCAL_TIME=1 export FASTSIM_DISABLE_TA=0 export FASTSIM_AUTO_SYNC=1
Pass
--quantum=1as model parameter.For single-chip platforms, pass
--min-sync-latency=0and for multichip platforms, pass--min-sync-latency=1also as model parameter.
Copyright (c) 2021-2023, Arm Limited. All rights reserved.
