ACPI Low Power Idle (LPI)
Overview of LPI test
ACPI Low Power Idle (LPI) mechanism allows an operating system to manage the power states of the processor power domain hierarchy. Neoverse Reference Design platforms support the c-states c0 (run state), c1 (WFI) and c3 (WFI with core powered down).
This document describes the procedure to validate LPI functionality, determining the number of times a particular CPU core switched to idle state and the total time the core has been in a idle state.
Download and build the required platform software
For downloading and building the platform firmware, refer Buildroot boot. To enable LPI from ACPI, update the LPI_EN variable
from SgiPlatform.dsc.inc before build. Also remember to enable stress-ng
binary from the buildroot config.
Procedure for validating LPI states
Boot the platform to buildroot command line prompt.
Run the command ‘nproc’ to get the cpu count in the system.
Read the idle state descriptor entry to know about the c-state information.
cat /sys/devices/system/cpu/cpu<x>/cpuidle/state<j>/desc Here, x = 0, 1, 2, ... (nproc -1) y = 0, 1, 2, ...
generally for RD platform:
state0: c1 (LPI1) state for CPUx
state1: c3 (LPI3) state for CPUx
state2: available only for plaforms having power control for CPU container and is the combined c3 (LPI3 for core and LPI2 for cluster) state for CPU and cluster.
To get the LPI statistics, read the ‘usage’ and ‘time’ entries:
cat /sys/devices/system/cpu/cpu<x>/cpuidle/state<y>/usage cat /sys/devices/system/cpu/cpu<x>/cpuidle/state<y>/time
Wake up all CPUs from sleep. The example shown below uses the ‘stress-ng’ utility. Run stress-ng utility for one second for all CPUs using the command
stress-ng -c <num_cpu> -t 1 Here num_cpu is the value obtained on step 2
Repeat step 4 and compare the usage and time values.
In a system with idle states enabled, the expectation is the ‘usage’ count should increment on each suspend-resume cycle. The value for ‘time’ specifies the total time period the core was in that particular state.
Note
In a system that supports state2, the usage count will increment for either state1 or for state2. This is applicable when a core is the last one to undergo sleep inside a container, then the core will request for a combined sleep state instead of core only power down.
Copyright (c) 2021-2023, Arm Limited. All rights reserved.
